hanoba
I am trying to use the ESP8266 module from the shop (with the additional 470uF capacitor) together with Sunray.
When using the module with the original firmware (version 1.5.4) the module was found:
[WiFiEsp] Initializing ESP module
[WiFiEsp] Initilization successful - 1.5.4
WiFi found!
However, it did not connect to my access point.
Therefore I made a firmware update to 2.2.1 (ESP8266_NONOS_SDK-2.2.1.zip) as described in the Sunray Wiki. The update worked without problems.
After the update, the module is no longer found and the following error message is shown in the console output:
WIFI (ESP8266) not found! If the problem persist, you may need to flash your ESP to firmware 2.2.1.
I hope someone can help...
Many thanks in advance!
WiFi found!
