SefanH
Ich möchte gerne eine LED mit einem Programm aus dem PFOD-Designer ein und ausschalten.
Ich bekomme es jedoch nicht hin einen Accesspoint zu erstellen und dort dann die Verbindung mit PFOD herzustellen...
Kann mir da jemand helfen? Der PFOD-Designer hat folgendes ausgegeben:
Ich bin hier ziemlich überfordert wie es scheint...
/* ===== pfod Command for Menu_2 ====
pfodApp msg {.} --> {,~<prompt not set>`0~V4|B~Buttontext|C~Button|A`0~PWM Setting ~%`255`0~100~0~}
// Using Serial and 9600 baud for send and receive
// Serial D0 (RX) and D1 (TX) on Arduino Uno, Micro, ProMicro, Due, Mega, Mini, Nano, Pro and Ethernet
// This code uses Serial so remove shield when programming the board
/* Code generated by pfodDesignerV3 V3.0.3871
* (c)2014-2021 Forward Computing and Control Pty. Ltd.
* NSW Australia, www.forward.com.au
* This code is not warranted to be fit for any purpose. You may only use it at your own risk.
* This generated code may be freely used for both private and commercial use
* provided this copyright is maintained.
// download the libraries from http://www.forward.com.au/pfod/pfodParserLibraries/index.html
// pfodParser.zip V3.51+ contains pfodParser, pfodSecurity, pfodDelay, pfodBLEBufferedSerial, pfodSMS and pfodRadio
#include <pfodParser.h>
int swap01(int); // method prototype for slider end swaps
pfodParser parser("V5"); // create a parser to handle the pfod messages
int cmd_A_var; // name the variable for 'PWM Setting'
unsigned long plot_mSOffset = 0; // set by {@} response
bool clearPlot = false; // set by the {@} response code
// the setup routine runs once on reset:
void setup() {
Serial.begin(9600);
for (int i=3; i>0; i--) {
// wait a few secs to see if we are being programmed
delay(1000);
parser.connect(&Serial); // connect the parser to the i/o stream
// <<<<<<<<< Your extra setup code goes here
// the loop routine runs over and over again forever:
void loop() {
uint8_t cmd = parser.parse(); // parse incoming data from connection
// parser returns non-zero when a pfod command is fully parsed
if (cmd != 0) { // have parsed a complete msg { to }
uint8_t* pfodFirstArg = parser.getFirstArg(); // may point to \0 if no arguments in this msg.
pfod_MAYBE_UNUSED(pfodFirstArg); // may not be used, just suppress warning
long pfodLongRtn; // used for parsing long return arguments, if any
pfod_MAYBE_UNUSED(pfodLongRtn); // may not be used, just suppress warning
if ('.' == cmd) {
// pfodApp has connected and sent {.} , it is asking for the main menu
if (!parser.isRefresh()) {
sendMainMenu(); // send back the menu designed
} else {
sendMainMenuUpdate(); // menu is cached just send update
// handle {@} request
} else if('@'==cmd) { // pfodApp requested 'current' time
plot_mSOffset = millis(); // capture current millis as offset rawdata timestamps
clearPlot = true; // clear plot on reconnect as have new plot_mSOffset
parser.print(F("{@`0}")); // return `0 as 'current' raw data milliseconds
// now handle commands returned from button/sliders
} else if('B'==cmd) { // user pressed -- 'Buttontext'
// in the main Menu of Menu_2
// << add your action code here for this button
parser.print(F("{}")); // change this return as needed.
// always send back a pfod msg otherwise pfodApp will disconnect.
} else if('C'==cmd) { // user pressed -- 'Button'
} else if('A'==cmd) { // user moved PWM slider -- 'PWM Setting'
parser.parseLong(pfodFirstArg,&pfodLongRtn); // parse first arg as a long
cmd_A_var = (int)pfodLongRtn; // set variable
sendMainMenuUpdate(); // always send back a pfod msg otherwise pfodApp will disconnect.
} else if ('!' == cmd) {
// CloseConnection command
closeConnection(parser.getPfodAppStream());
} else {
// unknown command
parser.print(F("{}")); // always send back a pfod msg otherwise pfodApp will disconnect.
// <<<<<<<<<<< Your other loop() code goes here
void closeConnection(Stream *io) {
// add any special code here to force connection to be dropped
void sendMainMenu() {
// !! Remember to change the parser version string
// every time you edit this method
parser.print(F("{,")); // start a Menu screen pfod message
// send menu background, format, prompt, refresh and version
parser.print(F("~<prompt not set>`0"));
parser.sendVersion(); // send the menu version
// send menu items
parser.print(F("|B"));
parser.print(F("~Buttontext"));
parser.print(F("|C"));
parser.print(F("~Button"));
parser.print(F("|A"));
parser.print('`');
parser.print(cmd_A_var); // output the current value
parser.print(F("~PWM Setting ~%`255`0~100~0~"));
parser.print(F("}")); // close pfod message
void sendMainMenuUpdate() {
parser.print(F("{;")); // start an Update Menu pfod message
// send menu items
parser.print('`');
// ============ end of menu ===========
int swap01(int in) {
return (in==0)?1:0;
// ============= end generated code =========
// pfodApp V3.0.3871,local time,UTC,mS per day,pfodDesignerV3 current time(mS),pfodDesignerV3 current time,
// connected at,2021/05/24 13:48:08.961,2021/05/24 11:48:08.961,86400000,0,2021/05/24 11:48:08.939
