Hello
First, sorry to write in english, but although I can more or less read german, I'm unable to write it.
I just realize the interference protection of the mower
motor, as recommended, but I could not find any practical information or picture about it.
So I share some pictures of what I did if it can help other people.
First open the
motor and just keep the upper platine.
Because there is no place to access the mass, we first need to create one. For that we will finish to drill the hole on the right side (3 mm diameter). It's only a few millimeters to go through. Then use a brass screw and fix it with a nut on the outer side. Then the 3 capacitors can be soldered. The next picture avoid any need for further description;
Then we will secure the nut on the screw with a welding point so it won't unscrew through vibration ! Again a picture
Before closing the
motor, do not forget to clean all the metal dust from drilling and soldering.
For the wheel
motor I follow the explanation of the "
Motor-EntstoerungREV20150531.pdf" but I let the extra capacitor inside, so there is no risk to tear it away.
Jacques
https://forum.ardumower.de/data/media/kunena/attachments/2809/Mower0.jpg/
