Got the parts from the shop and about to start assembling perimeter sender.
As I'm learning (everything, including soldering on the go), I want to double-check some things before getting into making HW (I'm more software person).
According the schema in https://github.com/Ardumower/ardumo...ossen/Platinenbilder/Sender_v2 Schaltplan.pdf DuoLED are connected in Green-Red and Red-Green sequence, but if I understand correctly images here: https://www.ardumower.de/index.php/de/forum/ardumower-platinen/586-ardumower-sender-board#6419 they are connected Red-Green and Green-Red sequence.
- Which one is correct (or I get the pins wrong)?
I understand that the difference will be the colors reversed, but ... still I would prefer green, when it should be green without re-soldering or changing software settings unnecessary
- Is it correct that INA169 has always to be bridged to 5A as it is shown in https://www.ardumower.de/index.php/...er-board-was-geht-da-schon-und-was-nicht#9231 ?
- I'm not sure that I get the pins to be connected on INA169 board right, but I assume that it should be Ok if connected as shown in https://www.ardumower.de/index.php/...er-board-was-geht-da-schon-und-was-nicht#9231 (bottom row and two top pins)?
- Resistors on the boards are all the same, except one (at least kit has 6 same and one different kind of)? (curious, because some pictures looks like have several types of resistors on them)
Thanks,
Romualdas
Thanks,
Romualdas
