runtimeterror
Moderator
Compiling from source results in several warnings:
Some of them look harmful to me.
Shall I open some issues on GitHub or is anyone already in charge of fixing them?
In file included from /tmp/arduino_build_799534/sketch/mower.h:11:0,
from /tmp/arduino_build_799534/sketch/config.h:1,
from /home/kai/dev/ardumower/ardumower/code/ardumower/ardumower.ino:42:
/tmp/arduino_build_799534/sketch/robot.h:373:57: warning: large integer implicitly truncated to unsigned type [-Woverflow]
RunningMedian perimeterMagMedian = RunningMedian(300);
/tmp/arduino_build_799534/sketch/robot.h: In member function 'virtual int Robot::readSensor(char)':
/tmp/arduino_build_799534/sketch/robot.h:568:39: warning: no return statement in function returning non-void [-Wreturn-type]
virtual int readSensor(char type){}
/tmp/arduino_build_799534/sketch/robot.h: At global scope:
/tmp/arduino_build_799534/sketch/robot.h:568:17: warning: unused parameter 'type' [-Wunused-parameter]
/tmp/arduino_build_799534/sketch/robot.h:571:18: warning: unused parameter 'type' [-Wunused-parameter]
virtual void setActuator(char type, int value){}
/tmp/arduino_build_799534/sketch/robot.h:571:18: warning: unused parameter 'value' [-Wunused-parameter]
/tmp/arduino_build_799534/sketch/robot.h:657:18: warning: unused parameter 'quick' [-Wunused-parameter]
virtual void configureBluetooth(boolean quick){};
