senil
Hello everyone,
I think it is convenient to comment on the possible problems that may arise after the assembly and operation of the charging base that comes as a Kit in the Marotronics store.
It should be noted in the Kiwi that the assembly of the contact plates should not be placed below the line of the upper cover of the mower, since it may happen that the Rover does not stop after contact with the terminals, which causes the top cover comes into contact with the two plates and a short circuit occurs.
This is what happened to me, and unfortunately something has burned inside it since now it has stopped charging, either through the charging base or through the plug in the Rover itself.
In my opinion, part of the plates should be insulated using electrical tape, in such a way that it does not come into contact with the lid. The front profile of the lid could also be insulated for a better guarantee.
I'm sorry for the bad indications in the images.
Greetings.
Ardumower Ladestation - Bausatz - Universell einsetzbar - Auch für Ihren Ardumow, 99,00 €
Endlich ist sie da: Die offizielle Ardumower Ladestation. Der Bausatz kann flexibel konfiguriert werden und ist damit universell einsetzbar. Die Kompatibilität zum Ardumower-Komplettset Modell 2021 ist garantiert.
www.marotronics.de
Greetings.
