Hello
I had a short circuit at the level of ina 69 (insect that burned ...). I replaced the card but I have since a problem the value of the current is negative (-0.02 A) the value of tension is good and varies well when it returns to charge at the base. But the charge does not start (the relay does not stop changing state).
Do you have any idea where the problem is coming from and what should I check?
Thank you.
Thank you.
