Yes, As Roland said, tristate led isn't used and also potentiometers are not used as default in the SW.
Only yellow led is important for you.
OFF = perimeter loop is open
ON = loop is closed and sender is sending signal
BLINKING = mower in station and charging
To set correct current, you must measure loop resistence and according this value set a voltage, but minimum voltage is aprox 6,5V !
Normaly loop resistence is around 2 Ohm so you must add a resistor (10 ohm/ 50w ) and then set a voltage ( 2 Ohm + 10 Ohm = 12 Ohm, If you want 0,8A then U = R*I = 12 * 0,8 = 9,6V )
Alex
