I loaded the latest version of your firmware. I can get BT connecting however the connection drops at least 70% of the time and it also have problems writing and saving settings. Also when I try the compass cal I do not get the usual beeping until it has enough data.
I am going to try a different BT module. Regards
Max
SETUP
--> ++++++++++++++++++++++++++++++++++* Start Robot Setup at 2502 --> +++++++++++++++++++++++++++
Load ErrorCounters
ErrorCounters address Start=500
ErrorCounters address Stop=522
LOAD UserSettings
UserSettings address Start=0
UserSettings address Stop=401
Load Robot Stats
Robot Stats address Start = 800
Robot Stats address Stop = 826
START
Ardumower 1.7-Azurit-ber
Config: Ardumower
press...
d for menu
v to change console output (sensor counters, values, perimeter etc.)
sen_counters
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 3827
t 1 Loops 0 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 0.0 chg 0.0 0.0 Ardumower
t 2 Loops 0 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 3 Loops 34108 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 4 Loops 34538 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
MAIN MENU:
1=test motors
2=test odometry
3=communications menu
5=calibrate IMU acc next side
6=calibrate IMU com start/stop
7=delete IMU calib
8=ADC calib (perimeter sender, charger must be off)
9=save user settings
l=load factory settings
r=delete robot stats
x=read settings
e=delete all errors
0=exit
MAIN MENU:
1=test motors
2=test odometry
7=delete IMU calib
x=read settings
e=delete all errors
0=exit
---------- wheel motors --------------------------------------
motorAccel : 1500
motorSpeedMaxRpm : 24
motorSpeedMaxPwm : 190
motorPowerMax : 26.00
motorSenseRightScale : 1.87
motorSenseLeftScale : 1.65
motorPowerIgnoreTime : 2000
motorZeroSettleTime : 2000
motorRollDegMax : 100
motorRollDegMin : 20
DistPeriOutRev : 40
DistPeriOutStop : 15
motorForwTimeMax : 80000
DistPeriObstacleCircle : 100
circleTimeForObstacle : 4000
motorRightOffsetFwd : 0
motorRightOffsetRev : 0
SpeedOdoMin : 50
SpeedOdoMax : 140
motorBiDirSpeedRatio1 : 0.30
motorBiDirSpeedRatio2 : 0.92
motorLeftPID.Kp : 1.00
motorLeftPID.Ki : 0.40
motorLeftPID.Kd : 0.00
motorRightSwapDir : 0
motorLeftSwapDir : 1
---------- mower
motor ---------------------------------------
motorMowForceOff : 1
motorMowAccel : 2000.00
motorMowSpeedMaxPwm : 200
motorMowPowerMax : 24.00
motorMowModulate : 0
motorMowRPMSet : 3300
motorMowSenseScale : 1.54
motorMowPID.Kp : 0.00
motorMowPID.Ki : 0.01
motorMowPID.Kd : 0.01
---------- bumper --------------------------------------------
bumperUse : 0
---------- drop ----------------------------------------------
dropUse : 0
dropContact : 0
---------- rain ----------------------------------------------
rainUse : 0
---------- sonar ---------------------------------------------
sonarUse : 0
sonarLeftUse : 0
sonarRightUse : 0
sonarCenterUse : 0
sonarTriggerBelow : 30
---------- perimeter -----------------------------------------
perimeterUse : 0
perimeterTriggerTimeout : 0
MaxSpeedperiPwm : 180
perimeterTrackRollTime : 1500
perimeterTrackRevTime : 2200
perimeterPID.Kp : 16.50
perimeterPID.Ki : 8.00
perimeterPID.Kd : 0.00
trackingPerimeterTransitionTimeOut : 1500
trackingErrorTimeOut : 10000
perimeterMagMaxValue : 2000
swapCoilPolarityRight : 0
read2Coil : 1
trackingBlockInnerWheelWhilePerimeterStruggling : 1
---------- By Lanes mowing ---------------------------------------
yawSet1 : 45.00
yawSet2 : 90.00
yawSet3 : 135.00
yawOppositeLane1RollRight : -125.00
yawOppositeLane2RollRight : -90.00
yawOppositeLane3RollRight : -35.00
yawOppositeLane1RollLeft : -131.00
yawOppositeLane2RollLeft : -87.00
yawOppositeLane3RollLeft : 60
DistBetweenLane : -42.00
maxLenghtByLane : 15
---------- lawn sensor ---------------------------------------
lawnSensorUse : 0
---------- IMU (compass/accel/gyro) --------------------------
imuUse : 0
stopMotorDuringCalib : 0
imuDirPID.Kp : 1.00
imuDirPID.Ki : 0.40
imuDirPID.Kd : 0.00
maxDriftPerSecond : 0.10
delayBetweenTwoDmpAutocalib : 300
maxDurationDmpAutocalib : 20
---------- model R/C -----------------------------------------
remoteUse : 0
---------- battery -------------------------------------------
batMonitor : 0
batGoHomeIfBelow : 24.70
batSwitchOffIfBelow : 23.70
batSwitchOffIfIdle : 1
batFactor : 10.25
batChgFactor : 10.89
batFull : 29.40
batChargingCurrentMax : 2.00
batFullCurrent : 0.10
startChargingIfBelow : 27.00
chargingTimeout : 12600000
chgSenseZero : 511.00
batSenseFactor : 20.00
chgSense : 185.00
chgChange : 0
chgNull : 2
---------- charging station ----------------------------------
stationRevDist : 15
stationRollAngle : 90
stationForwDist : 30
stationCheckDist : 20
---------- odometry ------------------------------------------
odometryTicksPerRevolution : 1575
odometryTicksPerCm : 20.00
odometryWheelBaseCm : 44.00
odometryRightSwapDir : 0
odometryLeftSwapDir : 0
---------- GPS -----------------------------------------------
gpsUse : 0
stuckIfGpsSpeedBelow : 0.20
gpsSpeedIgnoreTime : 5000
---------- other ---------------------------------------------
buttonUse : 1
mowPatternDurationMax : 30
---------- user-defined switch -------------------------------
userSwitch1 : 0
userSwitch2 : 0
userSwitch3 : 0
---------- timer ---------------------------------------------
timerUse : 0
---------- bluetooth-----------------------------------------
bluetoothuse : 1
---------- esp8266 ------------------------------------------
esp8266Use : 0
esp8266ConfigString : 123test321
---------- robot stats ---------------------------------------
statsMowTimeMinutesTrip : 0
statsMowTimeMinutesTotal : 300
statsBatteryChargingCounterTotal : 10
statsBatteryChargingCapacityTrip in mAh : 0.00
statsBatteryChargingCapacityTotal in Ah : 10.00
statsBatteryChargingCapacityAverage in mAh : 1000.00
Load Robot Stats
ALL USER SETTINGS ARE DELETED
Save Robot Stats
MAIN MENU:
1=test motors
2=test odometry
7=delete IMU calib
x=read settings
e=delete all errors
0=exit
pfod cmd=.
pfod cmd=.
pfod cmd=.
pfod cmd=.
pfod cmd=.
pfod cmd=.
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 119206
t 124 Loops 34538 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 125 Loops 26766 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 126 Loops 34140 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 127 Loops 34538 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 128 Loops 34537 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 129 Loops 34539 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 130 Loops 34538 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 131 Loops 34537 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 132 Loops 34539 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 133 Loops 34538 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 134 Loops 34537 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 135 Loops 34539 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 136 Loops 34537 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 137 Loops 34536 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s
t 138 Loops 34537 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 139 Loops 30264 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 140 Loops 34536 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
t 141 Loops 34535 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 142 Loops 26363 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
t 143 Loops 34536 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 59
t 144 Loops 26361 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 145 Loops 28430 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
t 146 Loops 34149 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
t 147 Loops 26375 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s
t 148 Loops 26377 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 149 Loops 30250 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 150 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 151 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 152 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 153 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 154 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 155 Loops 34531 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 156 Loops 30935 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 157 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 158 Loops 30935 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 159 Loops 30938 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 160 Loops 30949 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 161 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 24
t 162 Loops 30935 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 163 Loops 31786 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 164 Loops 34157 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 165 Loops 30950 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 102
t 166 Loops 30949 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 167 Loops 34496 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 168 Loops 34153 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 65
t 169 Loops 30934 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 170 Loops 33214 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 171 Loops 34161 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 172 Loops 30934 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 173 Loops 30950 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 174 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 175 Loops 30937 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 176 Loops 30938 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 177 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 178 Loops 30936 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 179 Loops 30949 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 180 Loops 30937 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 181 Loops 30947 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 182 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 183 Loops 30948 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 184 Loops 30936 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 185 Loops 30949 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 186 Loops 31230 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 187 Loops 34518 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s11
t 188 Loops 30935 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s
t 189 Loops 30951 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 190 Loops 30247 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 191 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 192 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 193 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 194 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 195 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 196 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 197 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 198 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 199 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 200 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 201 Loops 34534 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 202 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 203 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=.
t 204 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 205 Loops 32199 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=in
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 35
t 206 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 207 Loops 29953 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=in
t 208 Loops 34160 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=in
t 209 Loops 28735 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=.
t 210 Loops 28735 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 211 Loops 32199 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 212 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 213 Loops 34531 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 214 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 215 Loops 34530 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 216 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 217 Loops 34532 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 218 Loops 34531 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 219 Loops 34531 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 220 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 221 Loops 34530 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 222 Loops 34531 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s
t 223 Loops 34533 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 224 Loops 30249 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 158
t 225 Loops 34530 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 226 Loops 31854 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
t 227 Loops 34152 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
------------------------------------------------ LOOP NOT PERFECT DUE IS OVERLOAD ------------------------ Over 1 sec 130
t 228 Loops 26359 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
t 229 Loops 30882 v0 OFF odo 0 1 spd 0 0 0 sen 0 0 0 bum 0 0 dro 0 0 yaw 0 pit 0 rol 0 bat 10.2 chg 0.0 0.0 Ardumower
pfod cmd=s7
pfod cmd=g18
Reading sensors for first time... without any offset
Reading ax: 0 ay: 0 az: 0 gx: 0 gy: 0 gz: 0
Calculating offsets...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
Wait ...
