bitbucket2013@roontoon_com
Hi
I am in the middle of my PCB build and I have a question regarding ZD1, ZD2, ZD3
1) Am I correct that they should not be installed at all. And if so should I put a jumper wire in place of the diodes?
2) Also there are no values for R24, R25, R26, R19. Are they also not installed and if so should I have a jumper in place of the resistors?
After this I will be ready to power test the board so I am quite excited to get the answer to this.
Thanks for your help
Dan
Dan
