Starsurfer78
Moin,
ich habe hier einen Alfred stehen, bei dem der Bananapi defekt war, den habe ich gegen einen Pi3 ausgetauscht.
Die Verbindung zum GPS funktioniert (/dev/ttyACM0)
Aber ich bekomme keine Verbindung zum Alfred Board:
Hat jemand ein Tipp für mich?
SerialRobot: CRC ERROR
----starting sunray----
CMD=
working dir:/home/Sascha/Sunray/alfred
opening serial port /dev/ttyACM0...
opening serial port /dev/null...
BLE: run
BLE: l2cap le att listen and accept
BLE: listen
BLE: Started listening on ATT channel. Waiting for connections
main
LinuxConsole::begin
opening TTY...
TTY=0
SD card found!
RESET cause: unknown
Sunray,1.0.327
compiled for: Linux
using robot driver: SerialRobotDriver
setting baudrate /dev/ttyACM0 19200...
linux working dir (pwd): /home/Sascha/Sunray/alfred
reading robot ID...
ioboard init
IMU POWER STATE 1
FAN POWER STATE 1
turning LEDs green
starting ADC
ADC S1=0.44
ADC S2=0.08
ADC S3=0.04
ADC S4=1.61
ADC S5=1.61
ADC S6=0.00
ADC S7=0.65
ADC S8=1.75
robot id: dc:a6:32:50:87:16
enableCharging 0
RCModel disabled in config
using bumper driver: LiDAR
ENABLE_PASS
ENABLE_TILT_DETECTION
FREEWHEEL_IS_AT_BACKSIDE: 0
WHEEL_BASE_CM: 39
WHEEL_DIAMETER: 205
ENABLE_LIFT_DETECTION
LIFT_OBSTACLE_AVOIDANCE
ENABLE_ODOMETRY_ERROR_DETECTION: 0
TICKS_PER_REVOLUTION: 320
MOTOR_FAULT_CURRENT: 3.00
MOTOR_OVERLOAD_CURRENT: 1.20
USE_LINEAR_SPEED_RAMP: 0
MOTOR_PID_KP: 0.50
MOTOR_PID_KI: 0.01
MOTOR_PID_KD: 0.01
MOTOR_LEFT_SWAP_DIRECTION
MOTOR_RIGHT_SWAP_DIRECTION
MOW_FAULT_CURRENT: 8.00
MOW_OVERLOAD_CURRENT: 2.00
ENABLE_OVERLOAD_DETECTION: 0
ENABLE_FAULT_DETECTION: 1
ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
ENABLE_RPM_FAULT_DETECTION: 0
RAIN_ENABLE: 1
BUMPER_ENABLE: 1
BUMPER_DEADTIME: 1000
BUMPER_TRIGGER_DELAY: 0
BUMPER_MAX_TRIGGER_TIME: 30
LIDAR_BUMPER_ENABLE: 0
CURRENT_FACTOR: 0.50
GO_HOME_VOLTAGE: 25.50
BAT_FULL_VOLTAGE: 30.00
BAT_FULL_CURRENT: -0.10
BAT_SWITCH_OFF_IDLE: 0
BAT_SWITCH_OFF_UNDERVOLTAGE: 1
REQUIRE_VALID_GPS: 1
GPS_SPEED_DETECTION: 1
GPS_MOTION_DETECTION: 1
GPS_REBOOT_RECOVERY: 1
GPS_CONFIG: 1
GPS_CONFIG_FILTER: 1
CPG_CONFIG_FILTER_MINELEV: 10
CPG_CONFIG_FILTER_NCNOTHRS: 0
CPG_CONFIG_FILTER_CNOTHRS: 0
ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
OBSTACLE_DETECTION_ROTATION: 0
KIDNAP_DETECT: 1
KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
DOCKING_STATION: 1
DOCK_IGNORE_GPS: 0
DOCK_AUTO_START: 1
TARGET_REACHED_TOLERANCE: 0.10
STANLEY_CONTROL_P_NORMAL: 1.10
STANLEY_CONTROL_K_NORMAL: 0.10
STANLEY_CONTROL_P_SLOW: 1.10
STANLEY_CONTROL_K_SLOW: 0.10
BUTTON_CONTROL: 1
USE_TEMP_SENSOR: 1
BUZZER_ENABLE
SERIAL_BUFFER_SIZE=4096 (increase if you experience GPS checksum errors)
UBLOX::begin serial
setting baudrate /dev/ttyACM0 115200...
using gps driver: UBLOX
sizeof(short):2
sizeof(int):4
sizeof(long):8
sizeof(long long):8
sizeof(int16_t):2
sizeof(int32_t):4
sizeof(int64_t):8
ublox UBX-NAV-RELPOSNED decode test: relPosE=-7.52 TEST SUCCEEDED
ublox UBX-NAV-HPPOSLLH decode test: lat=52.26748477 TEST SUCCEEDED
trying to connect to ublox f9p...
NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
trying baud 115200
SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=0
GPS receiver found!
UBLOX protocol: 27.31
ublox f9p: sending GPS rover configuration...
idx=0...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=24
OK
idx=1...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=74
OK
idx=2...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=39
OK
idx=3...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=69
OK
idx=4...OK
idx=5...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=34
OK
idx=6...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=34
OK
idx=7...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=54
OK
idx=8...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=49
OK
idx=9...SFE_UBLOX_GPS::sendSerialCommand outgoingUBX->len=39
OK
config sent successfully
Map::begin
sizeof Point=8
map load... no map file!
map dump - mapCRC=0
perimeter pts: 0
exclusion pts: 0
exclusions: 0
dock pts: 0
mow pts: 0
free pts: 0
mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3
WiFiClass::findWifiInterface
found WiFi interface: wlan0
MAC: DC:A6:32:50:87:17
AP_MAC: EE:74:D7:2A:35:77
WiFi signal level: -38 dBm
server begin port 80
sockfd=11
server listening
MPU ID=0x68
MPU6050/9150 found
using imu driver: MpuDriver
resuming is activated
state load... File filename=state.bin mode=r
_fopen=-2013261968
ok
dumpState: X=-14.64 Y=-25.42 delta=0.94 mapCRC=0 mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=4 op=0 sensor=4 sonar.enabled=0 fixTimeout=0 absolutePosSource=0 lon=0.00 lat=0.00 pwmMaxMow=255 finishAndRestart=0 motorMowForwardSet=1 dockAfterFinish=1
timetable (UTC times) 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23
timetable (UTC times) mon * * * * * * * * * * *
timetable (UTC times) tue * * * * * * * * * * *
timetable (UTC times) wed * * * * * * * * * * *
timetable (UTC times) thu * * * * * * * * * * *
timetable (UTC times) fri * * * * * * * * * * *
timetable (UTC times) sat * * * * * * * * * * *
timetable (UTC times) sun * * * * * * * * * * *
* means mowing allowed
current GPS UTC weektime: dayOfWeek=mon hour=0
timetable enabled: 0
mowing allowed: 1
SerialRobot: CRC ERROR0,47
SerialRobot: CRC ERROR0,A
SerialRobot: CRC ERROR0,91
SerialRobot: CRC ERROR0,18
WARN: resetting motor ticks
WARN: SerialRobot unmet communication frequency: motorFreq=1/0 summaryFreq=1/0
Process::available - not executed
FAN POWER STATE 0
WARN: PID unmet cycle time Ta=3.79 TaMax=0.10
batTemp=-9999 cpuTemp=30
GPS time (UTC): dayOfWeek=sun hour=0
AUTOSTOP: timetable is disabled
AUTOSTART: not docked automatically (use DOCK command first)
==> changeOp:ImuCalibration(initiatedByOperator 0)->Idle
IMU gyro calibration (robot must be static)... 1
0:0:5 ctlDur=0.00 op=ImuCalibration(initiatedByOperator 0)->Idle mem=3348 bat=0.00,0.000(0.00) chg=0.00,0(0.00) diff=0.000 tg=0.00,0.00 x=-14.64 y=-25.42 delta=0.94 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=-7.52 d=0.00 sol=0 age=5.88
SerialRobot: CRC ERROR0,7D
SerialRobot: CRC ERROR0,98
WARN: PID unmet cycle time Ta=1.07 TaMax=0.10
IMU gyro calibration (robot must be static)... 2
sending encryptMode=1 encryptChallenge=135
HTTP WARN: high server duration: 1006
SerialRobot: CRC ERROR0,17
SerialRobot: CRC ERROR3,59
WARN: SerialRobot unmet communication frequency: motorFreq=13/0 summaryFreq=1/0
charger conn=0 chgEnabled=0 chgTime=0 charger: 0.00 V 0.00 A bat: 28.00 V diffV=-0.28 slope(v/min)=0.00 slopeLowCounter=1
WARN: PID unmet cycle time Ta=1.02 TaMax=0.10
IMU gyro calibration (robot must be static)... 3
WIF:$7m6nr[su
WIF(decrypt):AT+S,0x13
WIF:$7m6tnr[vw
WIF(decrypt):AT+S2,0x45
SerialRobot: CRC ERROR0,85
WIF:$7m7nr[sv
WIF(decrypt):AT+T,0x14
WIF:$7m3nrnrnrnr[tv
WIF(decrypt):AT+P,0,0,0,0x24
absolutePosSource=0 lon=0.00000000 lat=0.00000000
WIF:$7m3nrnrnrnr[tv
WARN: SerialRobot unmet communication frequency: motorFreq=47/0 summaryFreq=1/0
IMU gyro calibration (robot must be static)... 4
WARNING - LoopTime: 1 min=0 mean=0.40 max=5875
%CPU PID USER COMMAND
4.0 629 Sascha python3 /home/Sascha/CaSSAndRA/CaSSAndRA/app.py
36.5 858 root /home/Sascha/Sunray/alfred/build/sunray
WARN: SerialRobot unmet communication frequency: motorFreq=48/0 summaryFreq=2/0
IMU gyro calibration (robot must be static)... 5
SerialRobot: CRC ERROR0,14
WIF:$7m6nr[su
0:0:10 ctlDur=0.03 op=ImuCalibration(initiatedByOperator 0)->Idle mem=3348 bat=28.00,0.000(0.00) chg=0.00,0(0.00) diff=-11.727 tg=0.00,0.00 x=-14.64 y=-25.42 delta=0.94 tow=593567000 lon=9.20308800 lat=53.60753279 h=51.2 n=0.00 e=-7.52 d=0.00 sol=0 age=10.88
WARN: SerialRobot unmet communication frequency: motorFreq=47/0 summaryFreq=2/0
IMU gyro calibration (robot must be static)... 6
IMU gyro calibration (robot must be static)... 7
SerialRobot: CRC ERROR0,EC
WIF:$7m6nr[su
