Silberstreifen
With the BL adapter the board is fine. And when I connect the JYQD the fuse immediately blows.
Maybe wrong wiring BL-Adapter <-> JYQDWith the BL adapter the board is fine. And when I connect the JYQD the fuse immediately blows.
I can rule that out. The adapter was already running with exactly this wiring. Then I didn't touch the mower for 14 days. The problem has existed since then. And as I said, the adapter works on the laboratory power supply.Maybe wrong wiring BL-Adapter <-> JYQD
No, I haven't tested that. What is the effect supposed to be?Does it blow if you connect the JYQD to one of the gear sockets intead of the mow one?
yes, I did'nt change anything between propper work and blowing fuse.I ment your wiring from Adapter to JYQD
Das gucke ich mir an. Das kann passiert sein. Der Treiber war vorher frei fliegend montiert. Jetzt habe ich ihn auf einen gedruckten Adapter geschraubt. Vielleicht hat sich dabei ja etwas gelöst.Schau auch mal unter dem BL-Adapter nach.
To rule out the BL adapter, if it blows on some sockets and not others then that would probably mean there is something dead in the adapter.No, I haven't tested that. What is the effect supposed to be?
Woran kann das jetzt liegen? Das Labornetzteil zeigt 7W an.
Mit dem MOTOR_DRIVER_BRUSHLESS ist dagegen alles gut. Ist das bei euch auch so?ERROR motor current too high: current=6.23,6.31,6.29
// for brushless motors, study the sections (drivers, adapter, protection etc.) in the Wiki (https://wiki.ardumower.de/index.php?title=DIY_Brushless_Driver_Board)
#define MOTOR_DRIVER_BRUSHLESS 1 // uncomment this for new brushless motor drivers
//#define MOTOR_DRIVER_BRUSHLESS_MOW_DRV8308 1 // uncomment for brushless DRV8308 driver and mowing motor
//#define MOTOR_DRIVER_BRUSHLESS_MOW_A4931 1 // uncomment for brushless A3931 driver and mowing motor
//#define MOTOR_DRIVER_BRUSHLESS_MOW_BLDC8015A 1 // uncomment for brushless BLDC8015A driver and mowing motor
#define MOTOR_DRIVER_BRUSHLESS_MOW_JYQD 1 // uncomment for brushless JYQD driver and mowing motor (https://forum.ardumower.de/threads/jyqd-treiber-und-sunray.24811/)
//#define MOTOR_DRIVER_BRUSHLESS_MOW_OWL 1 // uncomment for brushless owlDrive mowing motor
#define MOTOR_DRIVER_BRUSHLESS_GEARS_DRV8308 1 // uncomment for brushless DRV8308 driver and gear/traction motors
//#define MOTOR_DRIVER_BRUSHLESS_GEARS_A4931 1 // uncomment for brushless A4931 driver and gear/traction motors
//#define MOTOR_DRIVER_BRUSHLESS_GEARS_BLDC8015A 1 // uncomment for brushless BLDC8015A driver and gear/traction motors
//#define MOTOR_DRIVER_BRUSHLESS_GEARS_JYQD 1 // uncomment for brushless JYQD driver and gears/traction motor
//#define MOTOR_DRIVER_BRUSHLESS_GEARS_OWL 1 // uncomment for brushless owlDrive gears/traction motor
