As you might know from other posts I m trying to convert a Husqvarne automower 210c to an ardumower. Driver motors are working again with a maxon 24/2 brushless controller which can be connected to the arduino ( in the near future I hope).
These motors will run on 15v.but I would like to use the mower motor from the ardumower shop which runs on 24v. What should be the best solution:
1 Use another mower motor also on 15v?
2 use a 15v power supply and use a booster to generate 24v?
3 use a 24v power supply and use a converter to reduce it to 15v for the maxon motor drivers?
What would be the dis/advantages?
Thanks,
Geert
Thanks,
Geert
