skippa1978
Hallo Alexander,
ich habe für einen Test Cassandra auf einem frischen Debian 12 System installiert und erhalte beim Starten von Cassandra folgenden Fehler:
Cassandra startet auch nicht richtig durch, das Dashboard ist nicht erreichbar. Hast du eine Idee, was das Problem sein könnte? Danke.
2024-01-28 20:00:03 INFO Starting thread for data storage
2024-01-28 20:00:03 INFO Starting schedule thread
2024-01-28 20:00:03 INFO Connecting...
2024-01-28 20:00:03 INFO TX: AT+V,0x16
Exception in thread Thread-1:
File "/usr/lib/python3.11/threading.py", line 1038, in _bootstrap_inner
self.run()
File "/usr/lib/python3.11/threading.py", line 975, in run
self._target(*self._args, **self._kwargs)
File "/home/cassandra/.local/lib/python3.11/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/home/cassandra/.local/lib/python3.11/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/cassandra/.local/lib/python3.11/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/cassandra/.local/lib/python3.11/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/cassandra/CaSSAndRA/CaSSAndRA/app.py", line 132, in start
app = dash.Dash(
File "/home/cassandra/.local/lib/python3.11/site-packages/dash/dash.py", line 533, in __init__
self.init_app()
File "/home/cassandra/.local/lib/python3.11/site-packages/dash/dash.py", line 611, in init_app
self.enable_pages()
File "/home/cassandra/.local/lib/python3.11/site-packages/dash/dash.py", line 2082, in enable_pages
_import_layouts_from_pages(self.config.pages_folder)
File "/home/cassandra/.local/lib/python3.11/site-packages/dash/_pages.py", line 435, in _import_layouts_from_pages
spec.loader.exec_module(page_module)
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/home/cassandra/CaSSAndRA/CaSSAndRA/src/pages/state.py", line 9, in <module>
from src.components.state import map, buttongroupcontrol, state, modal, charts, stats
File "/home/cassandra/CaSSAndRA/CaSSAndRA/src/components/state/charts.py", line 15, in <module>
max_date_allowed=roverdata.state.iloc[-1]['timestamp'],
File "/home/cassandra/.local/lib/python3.11/site-packages/pandas/core/indexing.py", line 1103, in __getitem__
return self._getitem_axis(maybe_callable, axis=axis)
File "/home/cassandra/.local/lib/python3.11/site-packages/pandas/core/indexing.py", line 1656, in _getitem_axis
self._validate_integer(key, axis)
File "/home/cassandra/.local/lib/python3.11/site-packages/pandas/core/indexing.py", line 1589, in _validate_integer
raise IndexError("single positional indexer is out-of-bounds")
IndexError: single positional indexer is out-of-bounds
