I am in the middle of building out my brushed ardumower kit I purchased last year. I soldered identical wires up for each of the 3 sonar sensors, wired them up, then ran the AT+F test. The left and center sensor work as expected, but the right sensor outputs 1 or 0 somewhat randomly. I'm not sure if anyone has run into similar issues in the past.
I visually checked the cables, which all look identical and are hooked up the same way to the sensors. May do a continuity test if no one has any ideas. It just seems odd that the output is changing between 0 and 1 sometimes for the right sensor, rather than staying at some fixed value. The only other thing I could think of is maybe the pin configuration isn't correct, but I'm not sure how to go about determining that.
09:25:26.435 -> CON:AT+F
09:25:26.435 -> testing sensors for 60 seconds...
09:25:26.435 -> sonar (enabled,left,center,right,triggered): 1 36 25 1 1 bumper (left,right,triggered): 0 0 0
09:25:27.419 -> sonar (enabled,left,center,right,triggered): 1 34 25 1 1 bumper (left,right,triggered): 0 0 0
09:25:28.427 -> sonar (enabled,left,center,right,triggered): 1 27 25 1 1 bumper (left,right,triggered): 0 0 0
09:25:29.415 -> sonar (enabled,left,center,right,triggered): 1 26 25 1 1 bumper (left,right,triggered): 0 0 0
09:25:30.422 -> sonar (enabled,left,center,right,triggered): 1 26 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:31.415 -> sonar (enabled,left,center,right,triggered): 1 26 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:32.432 -> sonar (enabled,left,center,right,triggered): 1 25 23 1 1 bumper (left,right,triggered): 0 0 0
09:25:33.413 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:34.436 -> sonar (enabled,left,center,right,triggered): 1 25 24 0 1 bumper (left,right,triggered): 0 0 0
09:25:35.414 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:36.431 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:37.422 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:38.402 -> sonar (enabled,left,center,right,triggered): 1 26 26 1 1 bumper (left,right,triggered): 0 0 0
09:25:39.420 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:40.426 -> sonar (enabled,left,center,right,triggered): 1 25 24 0 1 bumper (left,right,triggered): 0 0 0
09:25:41.430 -> sonar (enabled,left,center,right,triggered): 1 26 24 0 1 bumper (left,right,triggered): 0 0 0
09:25:42.430 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:43.412 -> sonar (enabled,left,center,right,triggered): 1 26 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:44.409 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:45.396 -> sonar (enabled,left,center,right,triggered): 1 26 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:46.395 -> sonar (enabled,left,center,right,triggered): 1 26 23 1 1 bumper (left,right,triggered): 0 0 0
09:25:47.421 -> sonar (enabled,left,center,right,triggered): 1 26 23 1 1 bumper (left,right,triggered): 0 0 0
09:25:48.410 -> sonar (enabled,left,center,right,triggered): 1 25 24 1 1 bumper (left,right,triggered): 0 0 0
09:25:49.422 -> sonar (enabled,left,center,right,triggered): 1 25 25 1 1 bumper (left,right,triggered): 0 0 0
09:25:50.422 -> sonar (enabled,left,center,right,triggered): 1 26 30 1 1 bumper (left,right,triggered): 0 0 0
09:25:51.422 -> sonar (enabled,left,center,right,triggered): 1 36 33 1 1 bumper (left,right,triggered): 0 0 0
09:25:52.396 -> sonar (enabled,left,center,right,triggered): 1 69 48 1 1 bumper (left,right,triggered): 0 0 0
09:25:53.409 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:25:54.413 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:25:55.393 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:25:56.397 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:25:57.417 -> sonar (enabled,left,center,right,triggered): 1 69 46 1 1 bumper (left,right,triggered): 0 0 0
09:25:58.401 -> sonar (enabled,left,center,right,triggered): 1 69 46 1 1 bumper (left,right,triggered): 0 0 0
09:25:59.410 -> sonar (enabled,left,center,right,triggered): 1 70 46 0 1 bumper (left,right,triggered): 0 0 0
09:26:00.398 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:26:01.419 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:26:02.398 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:26:03.411 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:04.387 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:05.398 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:26:06.406 -> sonar (enabled,left,center,right,triggered): 1 70 46 1 1 bumper (left,right,triggered): 0 0 0
09:26:07.416 -> sonar (enabled,left,center,right,triggered): 1 69 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:08.384 -> sonar (enabled,left,center,right,triggered): 1 69 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:09.411 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:10.387 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:11.390 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:12.400 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:13.390 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:14.378 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:15.394 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:16.411 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:17.377 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:18.400 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:19.379 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:20.373 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:21.399 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:22.384 -> sonar (enabled,left,center,right,triggered): 1 70 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:23.382 -> sonar (enabled,left,center,right,triggered): 1 69 48 1 1 bumper (left,right,triggered): 0 0 0
09:26:24.394 -> sonar (enabled,left,center,right,triggered): 1 69 47 1 1 bumper (left,right,triggered): 0 0 0
09:26:25.383 -> sonar (enabled,left,center,right,triggered): 1 69 48 1 1 bumper (left,right,triggered): 0 0 0
09:26:26.323 -> end of sensor test - please ignore any IMU/GPS errors
