Hi All,
I am proud of you guys for the whole design and configuration of this machine. Great work!
First a short introduction. (I am Dutch so I am not a native English writer, so apologies in advance..)
Since a couple of weeks I am the proud owner of a "Black Sheep", the working title of my Mower..
As a non-technician I managed to build the Mower, assemble the board, and build the periwire-sender. With a fully charged battery my liddle darling cuts the grass with great precision. Bluetooth is up and running.
But..
I ran in to a problem that I am not able to solve, so any help would be greatly appreciated!
When I put my mower on my desk (wooden blocks underneath), and apply 29.3 volts to the "external charging pins" (screws on top, + / - appropriately!) the following things happen:
- I still can reach my Mower by Bluetooth => OK
- the mower senses the 29.3 volt => it is "in the charging dock" => OK
- the charging-LED on the front is turned ON => OK
- the Mower senses 29.3 Volts applied to the external pins => ...
- NO charging current => ..
- the relais starts to switch on / off with about 2-3 seconds interval. => ...
Does anybody have an idea what I am doing wrong?
- I installed the variable resistant (RV1). Do I have to turn it to a certain "value"?
- D3, D4, D10 are all in place
- as I have the newest board, D8 is installed as indicated on the board, (contrary to the "fehler" as described) => or wasn't this updated in the latest version of the board? (The LED is never switched on, though, and Bluetooth is working perfectly..)
Any help would be greatly appreciated!
Kind Regards,
Bart
But..
Kind Regards,
Bart
