Hello,
It seems I could improve perimeter v2 further (especially for short perimeter loops).
Theory: It works by removing the capacitor C1 (4,7n) on the receiver circuit which results in a so called 'differential signal', in other words skipping step 4 in this image: http://wiki.ardumower.de/images/f/fd/Perimeter_signal_steps.png
Steps: If you want to try this out, here are the steps:
1. Remove capacitor C1 (4,7n) in the receiver circuit: http://wiki.ardumower.de/images/e/eb/Perimeter_v2_receiver_circuit.jpg
2. Download latest Ardumower code from Github (05.April 2015 or later).
3. Via your Android device (pfodApp/ArduRemote), choose 'Settings->Perimeter->Use differential signal = YES'. Now you can compare the signal quality ('qty') via pfodApp ('Plot->Perimeter').
NOTE: You can always switch back to the normal signal again by simply chooseing 'Settings->Perimeter->Use differential signal = NO' in the pfodApp.
Also, there's a new option 'Swap coil polarity' in the settings too, so you can easily swap the polarity of the coil.
All your feedback on the differential signal test is welcome.
Regards,
Regards,
