Hi Folks,
After implementing improvements last winter and using the Ardumower several times; I am now seeing some issues with the perimeter wire signal. The Ardumower is mowing in it's area but sometimes catches "glitches" which results a detection as being outside of the area.
Last week I have monitored this behavior by plotting the perimeterMag signal. The glitches are clearly visible on a consecutive way. See also printscreen in attachment.
The improvements which I have done last winter:
- Mounted raspberry pi 3 on PCB 1.3 reserved area/slot;
- Added DC/DC convertor to supply the RPI3. DC/DC is located > 10 cm from the coil;
- Mounted the receiver + coil on a more professional way by using a 3D printed housing;
- Changed firmware from Azurit to AzuritBer (incl. commits from Apr 21, 2022)
I have crosschecked the signal code pattern. Both Sender and Ardumower are using the signal Code 1 - which is default. So this looks OK.
Is someone recognizing this issue ? Can it be a defect to the coil/receiver ? Bad contact ? OR is related to some disturbances coming from the DC/DC convertor (maybe from the power management chip of the RPI3?)
