Hello
Unclear if this is already mentioned on the forum (German is not my native language), I didn't really find meaningful threads.
Steps before:
Any help is appreciated, this build is already taking a massive amount of time more than expected.
Steps before:
- I believe to have done everything up to step 7 https://wiki.ardumower.de/index.php...TK_external_base_service_.28Internet-based.29
- using firmwareversion 1.0.298
- also the xbee module is available and configured with an NTRIP client
- also the arduino due seems to detect and configure the GPS (correctly)
19:32:54.639 -> ERROR: GPS receiver is not responding
19:32:54.639 -> trying baud 38400
19:32:54.883 -> GPS receiver found!
19:32:54.883 -> ublox f9p: sending GPS rover configuration...
19:32:54.883 -> idx=0...OK
19:32:54.924 -> idx=1...OK
19:32:54.924 -> idx=2...OK
19:32:54.924 -> config sent successfully
19:32:54.924 -> sizeof Point=4
19:32:54.924 -> map load... no map file!
19:32:54.924 -> map dump - mapCRC=0
19:32:54.924 -> points:
19:32:54.924 -> perimeter pts: 0
19:32:54.924 -> exclusion pts: 0
19:32:54.924 -> exclusions: 0
19:32:54.924 -> dock pts: 0
19:32:54.924 -> mow pts: 0
19:32:54.964 -> free pts: 0
19:32:54.964 -> mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3
- If I connect back with u-center, nothing of the NTRIP client seems configured/stored; I believe to understand from the sunray wiki, this should have happened (step 8: "Verify your NTRIP client connection data via ucenter (see further below)"
I don't really know what the arduino due exactly configures and considers successful.
without a direct USB cable to the NTRIP-module, the GPS-XBEE also does not blink but just bursts every 10ish seconds .
with the usb cable connected it blinks like every second
