Hi .
Station Area and Area 2 are not connected and need the use of 2 senders.
I want to mow on multiple perimeter AREA in Schedule mode.
The goal is that the mower mow Sunday using perimeter wire on station Area and monday on Area 2 with area2 wire and when finish, find again the area station to go charging.
Rfid Tag can be used to locate perfectly the changing area location on the wire.
I want to connect a ESP8266 on the sender to have a communication between the mower and the sender to start and stop the Signal (SigCode 1 on station And sigcode 2 on area 2).
Or is it possible to build a new sender using a Node MCU and small motor driver to send SigCode 2 (Don't need here to manage the charging station so maybe don't need the sender PCB board).
Do you think ESP can manage the High frequence sig code and the WIFI at the same Time ??????
Not really easy for me so if someone have idea it can help a lot.
By.
By.
