It's clear for me.
Remember it's robotics mower, so need to mow in total autonomous mode using timer.
It is the same as commercial robotics mower
Mower never know when one area is finish to mow (it's different on SUNRAY) So it's back to station according : Battery low ,Timer finish,or rain trig etc...
You only decide using timer if area1 need 2 hours per days to mow complete or more (same for other area 2 or 3) and adjust timer with start location according your visual result.
So to work well Tracking and docking need to work PERFECTLY and mower never need to cut more than 1 CM of grass on each run to have a good result.
For TAG it's not so easy.
Actually when mower leave one area to go to other one it use IMU to run in straight line and odometry to know where to stop. (Perimeter is not read and mower run without wire control)
BUT Imu is 2 deg accuracy so you can't find a tag when changing from area to other one (Tag can only locate directly on the perimeter wire).
see WIKI go to new area :
AzuritBer Pi Firmware RFID(English) — www.wiki.ardumower.de
