senil
Hello colleagues,
After the problems I had with the brushless controllers I decided to change them to brushed controllers.
I would need to check with you if there is anything I forgot.
Before the change it had these characteristics:
- PCB 1.4
- RTK GPS Kit
-Grand Central M4
- BL42 brushless motor
- Brushless Mower Motor 57BL03
- ArduMower Brushless Adapter V1.0
I have purchased the MC33926 brushed motors and controllers.
MA42 DC planetary gear motor 24 volt with HallIC 30-33 RPM 8mm shaft
DC motor 63 25 24 V, 8mm shaft
I have removed the Brushless Adapter and previous drivers.
I have also soldered the capacitors on C10 and C11.
I have also removed the capacitors.
Comment:
Uncomment:
Comment:
This is all I've done so far.
If anyone sees that I am missing something else, I will appreciate your comments.
Thank you so much!
Greetings.
- PCB 1.4
- RTK GPS Kit
-Grand Central M4
Comment:
// ...for the brushless motor april 2021 https://wiki.ardumower.de/index.php?title=Datei:BLUnit.JPG
//#define TICKS_PER_REVOLUTION 1300 / 2 // 1194/2 odometry ticks per wheel revolution
Uncomment:
// ...for the newer 42mm diameter motor (green connector) https://www.marotronics.de/MA42-DC-...-30-33-RPM-8mm-Welle-ab-2-Stueck-Staffelpreis
#define TICKS_PER_REVOLUTION 696 / 2 // odometry ticks per wheel revolution
Comment:
//#define MOTOR_DRIVER_BRUSHLESS 1 // uncomment this for new brushless motor drivers
//#define MOTOR_DRIVER_BRUSHLESS_MOW_DRV8308 1 // uncomment for brushless DRV8308 driver and mowing motor
//#define MOTOR_DRIVER_BRUSHLESS_GEARS_DRV8308 1 // uncomment for brushless DRV8308 driver and gear/traction motors
Thank you so much!
Greetings.
