Measured 3.3v between vcc and ground.
I switched sda and scl. rebooted and got error connecting to MPU6050.
Switched back to original and now it seems to be doing something.
I never test the PCB1.4 , but to be sure issue is on the IMU you can test the branch named MPU6050 on I2C1 and connect IMU on I2C1 port.
Normaly the I2C1 is directly connected to DUE without component between DUE and IMU
