Dear,
I bought NTRIP version of the ardumower, I've tried to search in the forum but this didn't lead to much hits (or my German search terms are the issue).
The issue is my Arduino due does not want to find the gps receiver (serial monitor log of the arduino due is below).
I'm looking for advice how to debug this issue.
- Up step 7 of the ntrip module configuration on the wiki, I believe to have configured all the settings: https://wiki.ardumower.de/index.php...TK_external_base_service_.28Internet-based.29 (screenshots from the u-center are below)
If these are the correct settings, I believe it should be configured fine ... . The GPS>XBEE led is blinking
- the module is connected to the pcb 1.4 as described here: https://wiki.ardumower.de/index.php?title=Ardumower_Sunray#RTK_rover
19:51:14.830 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)115200...
19:51:15.306 -> BLE: AT
19:51:15.862 -> OK
19:51:15.862 -> AT+T,0x14
19:51:16.038 -> Bluetooth 4.0/BLE (HM-10) module found!
19:51:16.558 -> BLE: AT+VERSION
19:51:16.854 -> +VERSION=ESP32 firmware V0.4.5,Bluetooth V4.0 LE
19:51:16.854 -> AT+V,0x16
19:51:17.569 -> BLE: AT+NAMEArdumower
19:51:17.845 -> +NAME=Ardumower
19:51:17.845 -> AT+S,0x13
19:51:18.557 -> BLE: AT+RESET
19:51:18.845 -> +RESET
19:51:19.061 -> RCModel disabled in config
19:51:19.061 -> ENABLE_PASS
19:51:19.061 -> ENABLE_TILT_DETECTION
19:51:19.061 -> FREEWHEEL_IS_AT_BACKSIDE: 1
19:51:19.061 -> WHEEL_BASE_CM: 36
19:51:19.061 -> WHEEL_DIAMETER: 250
19:51:19.061 -> ENABLE_ODOMETRY_ERROR_DETECTION: 0
19:51:19.061 -> TICKS_PER_REVOLUTION: 525
19:51:19.061 -> MOTOR_FAULT_CURRENT: 6.00
19:51:19.061 -> MOTOR_OVERLOAD_CURRENT: 0.80
19:51:19.061 -> USE_LINEAR_SPEED_RAMP: 0
19:51:19.061 -> MOTOR_PID_KP: 2.00
19:51:19.061 -> MOTOR_PID_KI: 0.03
19:51:19.061 -> MOTOR_PID_KD: 0.03
19:51:19.061 -> MOW_FAULT_CURRENT: 8.00
19:51:19.061 -> MOW_OVERLOAD_CURRENT: 2.00
19:51:19.061 -> ENABLE_OVERLOAD_DETECTION: 1
19:51:19.061 -> ENABLE_FAULT_DETECTION: 1
19:51:19.061 -> ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
19:51:19.061 -> ENABLE_RPM_FAULT_DETECTION: 0
19:51:19.061 -> SONAR_INSTALLED
19:51:19.061 -> SONAR_ENABLE: 1
19:51:19.061 -> SONAR_TRIGGER_OBSTACLES: 1
19:51:19.061 -> RAIN_ENABLE: 0
19:51:19.061 -> BUMPER_ENABLE: 0
19:51:19.061 -> BUMPER_DEADTIME: 1000
19:51:19.061 -> BUMPER_TRIGGER_DELAY: 0
19:51:19.061 -> BUMPER_MAX_TRIGGER_TIME: 30
19:51:19.061 -> CURRENT_FACTOR: 1.98
19:51:19.061 -> GO_HOME_VOLTAGE: 21.50
19:51:19.061 -> BAT_FULL_VOLTAGE: 28.70
19:51:19.061 -> BAT_FULL_CURRENT: 0.20
19:51:19.061 -> BAT_SWITCH_OFF_IDLE: 1
19:51:19.061 -> BAT_SWITCH_OFF_UNDERVOLTAGE: 1
19:51:19.061 -> REQUIRE_VALID_GPS: 1
19:51:19.061 -> GPS_SPEED_DETECTION: 1
19:51:19.061 -> GPS_MOTION_DETECTION: 1
19:51:19.061 -> GPS_REBOOT_RECOVERY: 1
19:51:19.061 -> GPS_CONFIG: 1
19:51:19.061 -> GPS_CONFIG_FILTER: 1
19:51:19.061 -> CPG_CONFIG_FILTER_MINELEV: 10
19:51:19.061 -> CPG_CONFIG_FILTER_NCNOTHRS: 10
19:51:19.061 -> CPG_CONFIG_FILTER_CNOTHRS: 30
19:51:19.061 -> ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
19:51:19.061 -> OBSTACLE_DETECTION_ROTATION: 1
19:51:19.061 -> KIDNAP_DETECT: 1
19:51:19.061 -> KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
19:51:19.061 -> DOCKING_STATION: 0
19:51:19.061 -> DOCK_IGNORE_GPS: 0
19:51:19.061 -> DOCK_AUTO_START: 1
19:51:19.061 -> TARGET_REACHED_TOLERANCE: 0.05
19:51:19.061 -> STANLEY_CONTROL_P_NORMAL: 3.00
19:51:19.061 -> STANLEY_CONTROL_K_NORMAL: 1.00
19:51:19.061 -> STANLEY_CONTROL_P_SLOW: 3.00
19:51:19.061 -> STANLEY_CONTROL_K_SLOW: 0.10
19:51:19.061 -> BUTTON_CONTROL: 1
19:51:19.061 -> USE_TEMP_SENSOR: 0
19:51:19.061 -> BUZZER_ENABLE
19:51:19.061 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
19:51:19.061 -> -----------------------------------------------------
19:51:19.061 -> UBLOX::begin serial
19:51:19.061 -> using gps driver: UBLOX
19:51:19.061 -> trying to connect to ublox f9p...
19:51:19.061 -> NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
19:51:19.061 -> trying baud 115200
19:51:22.360 -> ERROR: GPS receiver is not responding
19:51:22.360 -> trying baud 38400
19:52:49.306 -> ERROR: GPS receiver is not responding
19:52:49.306 -> trying baud 38400
19:52:52.606 -> ERROR: GPS receiver is not responding
19:52:52.606 -> trying baud 115200
19:53:21.071 -> +NAME=Ardumower
19:53:21.832 -> BLE: AT+RESET
19:53:22.074 -> +RESET
19:53:22.074 -> AT+T,0x14
19:53:22.309 -> RCModel disabled in config
19:53:22.309 -> ENABLE_PASS
19:53:22.309 -> ENABLE_TILT_DETECTION
19:53:22.309 -> FREEWHEEL_IS_AT_BACKSIDE: 1
19:53:22.309 -> WHEEL_BASE_CM: 36
19:53:22.309 -> WHEEL_DIAMETER: 250
19:53:22.309 -> ENABLE_ODOMETRY_ERROR_DETECTION: 0
19:53:22.309 -> TICKS_PER_REVOLUTION: 525
19:53:22.309 -> MOTOR_FAULT_CURRENT: 6.00
19:53:22.309 -> MOTOR_OVERLOAD_CURRENT: 0.80
19:53:22.309 -> USE_LINEAR_SPEED_RAMP: 0
19:53:22.309 -> MOTOR_PID_KP: 2.00
19:53:22.309 -> MOTOR_PID_KI: 0.03
19:53:22.309 -> MOTOR_PID_KD: 0.03
19:53:22.309 -> MOW_FAULT_CURRENT: 8.00
19:53:22.309 -> MOW_OVERLOAD_CURRENT: 2.00
19:53:22.309 -> ENABLE_OVERLOAD_DETECTION: 1
19:53:22.309 -> ENABLE_FAULT_DETECTION: 1
19:53:22.309 -> ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
19:53:22.309 -> ENABLE_RPM_FAULT_DETECTION: 0
19:53:22.309 -> SONAR_INSTALLED
19:53:22.309 -> SONAR_ENABLE: 1
19:53:22.309 -> SONAR_TRIGGER_OBSTACLES: 1
19:53:22.309 -> RAIN_ENABLE: 0
19:53:22.309 -> BUMPER_ENABLE: 0
19:53:22.309 -> BUMPER_DEADTIME: 1000
19:53:22.309 -> BUMPER_TRIGGER_DELAY: 0
19:53:22.309 -> BUMPER_MAX_TRIGGER_TIME: 30
19:53:22.309 -> CURRENT_FACTOR: 1.98
19:53:22.309 -> GO_HOME_VOLTAGE: 21.50
19:53:22.309 -> BAT_FULL_VOLTAGE: 28.70
19:53:22.309 -> BAT_FULL_CURRENT: 0.20
19:53:22.309 -> BAT_SWITCH_OFF_IDLE: 1
19:53:22.309 -> BAT_SWITCH_OFF_UNDERVOLTAGE: 1
19:53:22.309 -> REQUIRE_VALID_GPS: 1
19:53:22.309 -> GPS_SPEED_DETECTION: 1
19:53:22.309 -> GPS_MOTION_DETECTION: 1
19:53:22.309 -> GPS_REBOOT_RECOVERY: 1
19:53:22.309 -> GPS_CONFIG: 1
19:53:22.309 -> GPS_CONFIG_FILTER: 1
19:53:22.309 -> CPG_CONFIG_FILTER_MINELEV: 10
19:53:22.309 -> CPG_CONFIG_FILTER_NCNOTHRS: 10
19:53:22.309 -> CPG_CONFIG_FILTER_CNOTHRS: 30
19:53:22.309 -> ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
19:53:22.309 -> OBSTACLE_DETECTION_ROTATION: 1
19:53:22.309 -> KIDNAP_DETECT: 1
19:53:22.309 -> KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
19:53:22.309 -> DOCKING_STATION: 0
19:53:22.309 -> DOCK_IGNORE_GPS: 0
19:53:22.309 -> DOCK_AUTO_START: 1
19:53:22.309 -> TARGET_REACHED_TOLERANCE: 0.05
19:53:22.309 -> STANLEY_CONTROL_P_NORMAL: 3.00
19:53:22.309 -> STANLEY_CONTROL_K_NORMAL: 1.00
19:53:22.309 -> STANLEY_CONTROL_P_SLOW: 3.00
19:53:22.309 -> STANLEY_CONTROL_K_SLOW: 0.10
19:53:22.309 -> BUTTON_CONTROL: 1
19:53:22.309 -> USE_TEMP_SENSOR: 0
19:53:22.309 -> BUZZER_ENABLE
19:53:22.309 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
19:53:22.309 -> -----------------------------------------------------
19:53:22.309 -> UBLOX::begin serial
19:53:22.309 -> using gps driver: UBLOX
19:53:22.309 -> trying to connect to ublox f9p...
19:53:22.309 -> NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
19:53:22.309 -> trying baud 115200
19:53:25.617 -> ERROR: GPS receiver is not responding
19:53:25.617 -> trying baud 38400
19:53:28.903 -> ERROR: GPS receiver is not responding
19:53:28.903 -> trying baud 115200
19:53:52.930 -> I2C bus error. Could not clear (PCB not powered ON or RTC module missing or JCx jumper set for missing I2C module)
19:53:52.930 -> SCL clock line held low
19:53:55.450 -> I2C bus error. Could not clear (PCB not powered ON or RTC module missing or JCx jumper set for missing I2C module)
19:53:55.450 -> SCL clock line held low
19:53:56.928 -> SD card found!
19:53:56.928 -> RESET cause: unknown
19:53:56.928 -> Sunray,1.0.298
19:53:56.928 -> compiled for: Arduino Due
19:53:56.928 -> using robot driver: AmRobotDriver
19:53:56.928 -> robot id: 36:04:31:20:33:35:24:55:30:30:31:31:39:30:30:37
19:53:56.928 -> MOTOR_DRIVER_BRUSHLESS: no
19:53:56.928 -> enableCharging 0
19:53:56.928 -> probing for HM-10 module (NOTE: will fail for ESP32)...
19:53:56.928 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)9600...
19:53:57.431 -> BLE: AT
19:53:57.431 -> }trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)115200...
19:53:58.156 -> BLE: AT
19:53:58.414 -> OK
19:53:58.467 -> AT+V,0x16
19:53:58.637 -> Bluetooth 4.0/BLE (HM-10) module found!
19:53:59.152 -> BLE: AT+VERSION
19:53:59.428 -> +VERSION=ESP32 firmware V0.4.5,Bluetooth V4.0 LE
19:53:59.428 -> AT+S,0x13
19:54:00.138 -> BLE: AT+NAMEArdumower
19:54:00.456 -> +NAME=Ardumower
19:54:01.140 -> BLE: AT+RESET
19:54:01.478 -> +RESET
19:54:01.746 -> RCModel disabled in config
19:54:01.746 -> ENABLE_PASS
19:54:01.746 -> ENABLE_TILT_DETECTION
19:54:01.746 -> FREEWHEEL_IS_AT_BACKSIDE: 1
19:54:01.746 -> WHEEL_BASE_CM: 36
19:54:01.746 -> WHEEL_DIAMETER: 250
19:54:01.746 -> ENABLE_ODOMETRY_ERROR_DETECTION: 0
19:54:01.746 -> TICKS_PER_REVOLUTION: 525
19:54:01.746 -> MOTOR_FAULT_CURRENT: 6.00
19:54:01.746 -> MOTOR_OVERLOAD_CURRENT: 0.80
19:54:01.746 -> USE_LINEAR_SPEED_RAMP: 0
19:54:01.746 -> MOTOR_PID_KP: 2.00
19:54:01.746 -> MOTOR_PID_KI: 0.03
19:54:01.746 -> MOTOR_PID_KD: 0.03
19:54:01.746 -> MOW_FAULT_CURRENT: 8.00
19:54:01.746 -> MOW_OVERLOAD_CURRENT: 2.00
19:54:01.746 -> ENABLE_OVERLOAD_DETECTION: 1
19:54:01.746 -> ENABLE_FAULT_DETECTION: 1
19:54:01.746 -> ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
19:54:01.746 -> ENABLE_RPM_FAULT_DETECTION: 0
19:54:01.746 -> SONAR_INSTALLED
19:54:01.746 -> SONAR_ENABLE: 1
19:54:01.746 -> SONAR_TRIGGER_OBSTACLES: 1
19:54:01.746 -> RAIN_ENABLE: 0
19:54:01.746 -> BUMPER_ENABLE: 0
19:54:01.746 -> BUMPER_DEADTIME: 1000
19:54:01.746 -> BUMPER_TRIGGER_DELAY: 0
19:54:01.746 -> BUMPER_MAX_TRIGGER_TIME: 30
19:54:01.746 -> CURRENT_FACTOR: 1.98
19:54:01.746 -> GO_HOME_VOLTAGE: 21.50
19:54:01.746 -> BAT_FULL_VOLTAGE: 28.70
19:54:01.746 -> BAT_FULL_CURRENT: 0.20
19:54:01.746 -> BAT_SWITCH_OFF_IDLE: 1
19:54:01.746 -> BAT_SWITCH_OFF_UNDERVOLTAGE: 1
19:54:01.746 -> REQUIRE_VALID_GPS: 1
19:54:01.746 -> GPS_SPEED_DETECTION: 1
19:54:01.746 -> GPS_MOTION_DETECTION: 1
19:54:01.746 -> GPS_REBOOT_RECOVERY: 1
19:54:01.746 -> GPS_CONFIG: 1
19:54:01.746 -> GPS_CONFIG_FILTER: 1
19:54:01.746 -> CPG_CONFIG_FILTER_MINELEV: 10
19:54:01.746 -> CPG_CONFIG_FILTER_NCNOTHRS: 10
19:54:01.746 -> CPG_CONFIG_FILTER_CNOTHRS: 30
19:54:01.746 -> ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
19:54:01.746 -> OBSTACLE_DETECTION_ROTATION: 1
19:54:01.746 -> KIDNAP_DETECT: 1
19:54:01.746 -> KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
19:54:01.746 -> DOCKING_STATION: 0
19:54:01.746 -> DOCK_IGNORE_GPS: 0
19:54:01.746 -> DOCK_AUTO_START: 1
19:54:01.746 -> TARGET_REACHED_TOLERANCE: 0.05
19:54:01.746 -> STANLEY_CONTROL_P_NORMAL: 3.00
19:54:01.746 -> STANLEY_CONTROL_K_NORMAL: 1.00
19:54:01.746 -> STANLEY_CONTROL_P_SLOW: 3.00
19:54:01.746 -> STANLEY_CONTROL_K_SLOW: 0.10
19:54:01.746 -> BUTTON_CONTROL: 1
19:54:01.746 -> USE_TEMP_SENSOR: 0
19:54:01.746 -> BUZZER_ENABLE
19:54:01.746 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
19:54:01.746 -> -----------------------------------------------------
19:54:01.746 -> UBLOX::begin serial
19:54:01.746 -> using gps driver: UBLOX
19:54:01.746 -> trying to connect to ublox f9p...
19:54:01.746 -> NOTE: if GPS is not responding either set 'GPS_CONFIG=false' in config.h or perform GPS wire fix (see Wiki)
19:54:01.746 -> trying baud 115200
19:54:04.983 -> ERROR: GPS receiver is not responding
19:54:04.983 -> trying baud 38400
19:54:08.274 -> ERROR: GPS receiver is not responding
19:54:08.274 -> trying baud 115200
