// this is a pololu motor test
// -----> SOFTWARE PER MC33296 da SVN versione <--------
// MC33926 motor driver //--->QUI 5/01/2015
// Check [URL]http://forum.pololu.com/viewtopic.php?f=15&t=5272#p25031[/URL] for explanations.
//(8-bit PWM=255, 10-bit PWM=1023)
// IN1 PinPWM IN2 IN2
// PWM L Forward
// nPWM H Reverse
//void setMC33926(int IN2, int pinPWM, int speed){
// if (speed < 0){
// digitalWrite(IN2, HIGH) ;
// analogWrite(pinPWM, 255-((byte)abs(speed)));
// } else {
// digitalWrite(IN2, LOW) ;
// analogWrite(pinPWM, ((byte)speed));
//MC33926: PER motorsense
//resolution 525mV / A
//with 0 A is output also 0V and on AD pin I will read 0
//with 5 A is output 2,625 V and on the AD pin I will read 538
//Esempio:
//5A x 0.525V/A = 2.625V
// il pin leggeraà 2.625V x 1023 / 5V = 538
//NB: gli analog pin leggono 0-1023 0-5V
int pwm;
int ledPin = 13;
int statuspin;
int row=0; //per il seriale
int IN1 = 11; //----> IN1 (Pin Input PWM, PWM or -PWM)
int IN2= 7; //----> IN2 (Pin DIR, L o H)
int pinmotorfault= A4; //----> M2SF (fault)
int pinmotorsense= A2; //----> M2FB (sense) 525mV/A
int motorPinEn= 8; //----> EN (abilita motori)
//letture
int ledStat;
int motorStat;
float senseStat;
float senseAmp;
int faultStat;
void setup()
// definizioni
pinMode(ledPin,OUTPUT);
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(pinmotorfault,INPUT);
pinMode(pinmotorsense,INPUT);
pinMode(motorPinEn,OUTPUT);
// settaggi iniziali
digitalWrite(ledPin,LOW); // setto il led spento
digitalWrite(motorPinEn,HIGH); // non abilito i motori perchè sono su 5V
analogWrite(IN1,0); // setto la velocità nulla iniziale
//contatto con la seriale
Serial.begin(9600);
void loop()
// STAMPA TUTTI I VALORI
row++;
if (row>15)
row=0;
Serial.println("ROW,SET,2");
Serial.println("CLEARDATA");
//FORWARD
pwm=50;
digitalWrite(ledPin,HIGH); //led acceso
digitalWrite(IN2,LOW); //Forward
analogWrite(IN1,pwm);
delay(5);
ledStat=digitalRead(ledPin);
motorStat=digitalRead(IN2);
do {//continua a leggere il valore di corrente fino a che è diverso da 0
senseStat=analogRead(pinmotorsense);
delay(5);
senseAmp = 5*senseStat/1023/0.525*1000; // trasformo in milliAmpere (attenzione: prima divido e poi moltiplico, altrimenti vado fuori con la dimensione della variabile)
} while(senseAmp==0);
faultStat=digitalRead(pinmotorfault);
delay(5);
Serial.print("DATA,TIME,"); Serial.print("AVANTI"); Serial.print(",LED,"); Serial.print(ledStat); Serial.print(",IN1[PWM],"); Serial.print(pwm);Serial.print(",IN2[DIR],"); Serial.print(motorStat);Serial.print(",sense[mA],"); Serial.print(senseAmp);Serial.print(",fault [1=ok],"); Serial.println(faultStat);
faultStat=0;
delay(2000);
//ZERO
pwm=1;
digitalWrite(ledPin,LOW); //led spento
delay(5);
delay(5);
delay(5);
Serial.print("DATA,TIME,"); Serial.print("FERMO"); Serial.print(",LED,"); Serial.print(ledStat); Serial.print(",IN1[PWM],"); Serial.print(pwm);Serial.print(",IN2[DIR],"); Serial.print(motorStat);Serial.print(",sense[mA],"); Serial.print(senseAmp);Serial.print(",fault [1=ok],"); Serial.println(faultStat);
faultStat=0;
delay(2000);
//REVERSE
pwm=50;
digitalWrite(IN2,HIGH); //Reverse
analogWrite(IN1,255-pwm);
delay(5);
delay(5);
delay(5);
Serial.print("DATA,TIME,"); Serial.print("INDIETRO"); Serial.print(",LED,"); Serial.print(ledStat); Serial.print(",IN1[PWM],"); Serial.print(pwm);Serial.print(",IN2[DIR],"); Serial.print(motorStat);Serial.print(",sense[mA],"); Serial.print(senseAmp);Serial.print(",fault [1=ok],"); Serial.println(faultStat);
faultStat=0;
delay(2000);
//ZERO
pwm=1;
delay(5);
delay(5);
delay(5);
faultStat=0;
delay(2000);
