cozwei
Hallo
nachdem ich nun wieder eine RTC eingebaut habe, bootet mein Ardumower. Leider bekomme ich aber ständig einen COMM CRC ERROR.
Der Robot reagiert auf Serial Konsolenbefehle wie den Odometrietest. Wo muss ich den Fehler suchen?
21:40:57.918 -> RESET cause: power-on
21:40:57.918 -> Sunray,1.0.305
21:40:57.918 -> compiled for: Adafruit Grand Central M4
21:40:57.918 -> using robot driver: AmRobotDriver
21:40:57.918 -> robot id: eb:d6:42:90:53:35:37:4e:36:20:20:20:ff:03:1d:4b
21:40:57.918 -> MOTOR_DRIVER_BRUSHLESS: no
21:40:57.918 -> enableCharging 0
21:40:57.918 -> probing for HM-10 module (NOTE: will fail for ESP32)...
21:40:57.918 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)9600...
21:40:58.420 -> BLE: AT
21:41:00.400 -> trying to detect Bluetooth 4.0/BLE (HM-10 module) (make sure your phone is NOT connected)115200...
21:41:00.901 -> BLE: AT
21:41:01.945 -> AT+V,0x16
21:41:02.157 -> error: no BLE module found!
21:41:02.157 -> RCModel disabled in config
21:41:02.157 -> ENABLE_PASS
21:41:02.157 -> ENABLE_TILT_DETECTION
21:41:02.157 -> FREEWHEEL_IS_AT_BACKSIDE: 1
21:41:02.157 -> WHEEL_BASE_CM: 36
21:41:02.157 -> WHEEL_DIAMETER: 250
21:41:02.157 -> ENABLE_ODOMETRY_ERROR_DETECTION: 0
21:41:02.157 -> TICKS_PER_REVOLUTION: 377
21:41:02.157 -> MOTOR_FAULT_CURRENT: 6.00
21:41:02.157 -> MOTOR_OVERLOAD_CURRENT: 0.80
21:41:02.157 -> USE_LINEAR_SPEED_RAMP: 0
21:41:02.157 -> MOTOR_PID_KP: 2.00
21:41:02.157 -> MOTOR_PID_KI: 0.03
21:41:02.157 -> MOTOR_PID_KD: 0.03
21:41:02.157 -> MOTOR_RIGHT_SWAP_DIRECTION
21:41:02.157 -> MOW_FAULT_CURRENT: 8.00
21:41:02.157 -> MOW_OVERLOAD_CURRENT: 2.00
21:41:02.157 -> ENABLE_OVERLOAD_DETECTION: 1
21:41:02.157 -> ENABLE_FAULT_DETECTION: 1
21:41:02.157 -> ENABLE_FAULT_OBSTACLE_AVOIDANCE: 1
21:41:02.157 -> ENABLE_RPM_FAULT_DETECTION: 1
21:41:02.157 -> SONAR_INSTALLED
21:41:02.157 -> SONAR_ENABLE: 1
21:41:02.157 -> SONAR_TRIGGER_OBSTACLES: 1
21:41:02.157 -> RAIN_ENABLE: 0
21:41:02.157 -> BUMPER_ENABLE: 1
21:41:02.157 -> BUMPER_DEADTIME: 1000
21:41:02.157 -> BUMPER_TRIGGER_DELAY: 0
21:41:02.157 -> BUMPER_MAX_TRIGGER_TIME: 30
21:41:02.157 -> CURRENT_FACTOR: 1.98
21:41:02.157 -> GO_HOME_VOLTAGE: 21.50
21:41:02.157 -> BAT_FULL_VOLTAGE: 28.70
21:41:02.157 -> BAT_FULL_CURRENT: 0.20
21:41:02.157 -> BAT_SWITCH_OFF_IDLE: 0
21:41:02.157 -> BAT_SWITCH_OFF_UNDERVOLTAGE: 1
21:41:02.157 -> REQUIRE_VALID_GPS: 0
21:41:02.157 -> GPS_SPEED_DETECTION: 1
21:41:02.157 -> GPS_MOTION_DETECTION: 1
21:41:02.157 -> GPS_REBOOT_RECOVERY: 1
21:41:02.157 -> GPS_CONFIG: 0
21:41:02.157 -> GPS_CONFIG_FILTER: 1
21:41:02.157 -> CPG_CONFIG_FILTER_MINELEV: 10
21:41:02.157 -> CPG_CONFIG_FILTER_NCNOTHRS: 10
21:41:02.157 -> CPG_CONFIG_FILTER_CNOTHRS: 30
21:41:02.157 -> ALLOW_ROUTE_OUTSIDE_PERI_METER: 1.00
21:41:02.157 -> OBSTACLE_DETECTION_ROTATION: 1
21:41:02.157 -> KIDNAP_DETECT: 1
21:41:02.157 -> KIDNAP_DETECT_ALLOWED_PATH_TOLERANCE: 1.00
21:41:02.157 -> DOCKING_STATION: 1
21:41:02.157 -> DOCK_IGNORE_GPS: 0
21:41:02.157 -> DOCK_AUTO_START: 1
21:41:02.157 -> TARGET_REACHED_TOLERANCE: 0.05
21:41:02.157 -> STANLEY_CONTROL_P_NORMAL: 3.00
21:41:02.157 -> STANLEY_CONTROL_K_NORMAL: 1.00
21:41:02.157 -> STANLEY_CONTROL_P_SLOW: 3.00
21:41:02.157 -> STANLEY_CONTROL_K_SLOW: 0.10
21:41:02.157 -> BUTTON_CONTROL: 1
21:41:02.157 -> USE_TEMP_SENSOR: 0
21:41:02.157 -> BUZZER_ENABLE
21:41:02.157 -> SERIAL_BUFFER_SIZE=1024 (increase if you experience GPS checksum errors)
21:41:02.157 -> -----------------------------------------------------
21:41:02.157 -> UBLOX::begin serial
21:41:02.157 -> using gps driver: UBLOX
21:41:02.157 -> sizeof Point=4
21:41:02.157 -> map dump - mapCRC=0
21:41:02.157 -> points:
21:41:02.157 -> perimeter pts: 0
21:41:02.157 -> exclusion pts: 0
21:41:02.157 -> exclusions: 0
21:41:02.157 -> dock pts: 0
21:41:02.157 -> mow pts: 0
21:41:02.157 -> free pts: 0
21:41:02.157 -> mowPointsIdx=0 dockPointsIdx=0 freePointsIdx=0 wayMode=3
21:41:02.157 -> probing for ESP8266 (NOTE: will fail for ESP32)...
21:41:02.654 -> WIFI (ESP8266) not found! If you have ESP8266 and the problem persist, you may need to flash your ESP to firmware 2.2.171
21:41:02.692 -> MPU9250 found
21:41:02.692 -> using imu driver: MpuDriver
21:41:04.026 -> WARN: PID unmet cycle time Ta=1.86 TaMax=0.10
21:41:04.130 -> batTemp=998 cpuTemp=32
21:41:04.130 -> ==> changeOp:ImuCalibration(initiatedByOperator 0)->Idle
21:41:04.130 -> IMU gyro calibration (robot must be static)... 1
21:41:04.130 -> 0:0:10 ctlDur=0.00 op=ImuCalibration(initiatedByOperator 0)->Idle freem=245291 sp=200000A4 bat=0.00,0.000(0.00) chg=0.00,0(0.00) diff=0.000 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=10.23
21:41:04.130 -> WARNING - LoopTime: 10225 - 10225 - 102.25 - 10225ms
21:41:05.141 -> IMU gyro calibration (robot must be static)... 2
21:41:06.138 -> IMU gyro calibration (robot must be static)... 3
21:41:07.137 -> IMU gyro calibration (robot must be static)... 4
21:41:07.740 -> sending encryptMode=1 encryptChallenge=10
21:41:08.125 -> IMU gyro calibration (robot must be static)... 5
21:41:09.127 -> 0:0:15 ctlDur=0.02 op=ImuCalibration(initiatedByOperator 0)->Idle freem=244763 sp=200013F4 bat=24.89,0.000(0.01) chg=0.09,0(0.00) diff=-11.510 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=15.23
21:41:09.127 -> IMU gyro calibration (robot must be static)... 6
21:41:10.158 -> IMU gyro calibration (robot must be static)... 7
21:41:10.733 -> COMM CRC ERROR: ;N%M&*r+-
21:41:11.153 -> IMU gyro calibration (robot must be static)... 8
21:41:12.157 -> IMU gyro calibration (robot must be static)... 9
21:41:13.154 -> IMU gyro calibration (robot must be static)... 10
21:41:14.162 -> 0:0:20 ctlDur=0.02 op=ImuCalibration(initiatedByOperator 0)->Idle freem=244763 sp=200013F4 bat=24.89,0.000(0.01) chg=0.10,0(0.00) diff=-19.846 tg=0.00,0.00 x=0.00 y=0.00 delta=0.00 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=20.23
21:41:14.162 -> Info - LoopTime: 6 - 2 - 2.95 - 7ms
21:41:14.162 -> IMU gyro calibration (robot must be static)... 11
21:41:15.137 -> IMU gyro calibration (robot must be static)... 12
21:41:16.172 -> IMU gyro calibration (robot must be static)... 13
21:41:16.745 -> COMM CRC ERROR: ;N%M&*r+-
21:41:17.159 -> IMU gyro calibration (robot must be static)... 14
21:41:18.146 -> IMU gyro calibration (robot must be static)... 15
21:41:18.218 -> ==> changeOp:Idle(initiatedByOperator 0)
21:41:18.218 -> OP_IDLE
21:41:19.149 -> 0:0:25 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.01) chg=0.08,0(0.00) diff=-22.958 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.26 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=25.23
21:41:22.727 -> COMM CRC ERROR: ;N%M&*r+-
21:41:24.138 -> 0:0:30 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.08,0(0.00) diff=-24.116 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.26 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=30.23
21:41:24.175 -> Info - LoopTime: 6 - 2 - 2.94 - 53ms
21:41:28.733 -> COMM CRC ERROR: ;N%M&*r+-
21:41:29.168 -> 0:0:35 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.90,0.000(0.02) chg=0.09,0(0.00) diff=-24.551 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=35.23
21:41:34.153 -> 0:0:40 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.10,0(0.00) diff=-24.711 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=40.24
21:41:34.153 -> Info - LoopTime: 3 - 2 - 2.92 - 4ms
21:41:34.717 -> COMM CRC ERROR: ;N%M&*r+-
21:41:39.171 -> 0:0:45 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.09,0(0.00) diff=-24.772 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=45.24
21:41:40.738 -> COMM CRC ERROR: ;N%M&*r+-
21:41:43.328 -> BUTTON 1s
21:41:44.181 -> 0:0:50 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,-0.000(0.02) chg=0.10,0(0.00) diff=-24.795 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.26 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=50.24
21:41:44.181 -> Info - LoopTime: 7 - 2 - 2.96 - 7ms
21:41:44.329 -> BUTTON 2s
21:41:45.347 -> BUTTON 3s
21:41:46.167 -> stateButton 3
21:41:46.743 -> COMM CRC ERROR: ;N%M&*r+-
21:41:49.170 -> 0:0:55 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.08,0(0.00) diff=-24.803 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=55.24
21:41:49.311 -> BUTTON 1s
21:41:50.120 -> stateButton 1
21:41:52.732 -> COMM CRC ERROR: ;N%M&*r+-
21:41:54.193 -> 0:1:0 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.09,0(0.00) diff=-24.810 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=60.24
21:41:54.193 -> Info - LoopTime: 6 - 2 - 2.94 - 6ms
21:41:54.694 -> BUTTON 1s
21:41:54.729 -> COMM CRC ERROR: ;N%N&*r+.
21:41:55.681 -> BUTTON 2s
21:41:55.993 -> stateButton 2
21:41:58.743 -> COMM CRC ERROR: ;N%M&*r+-
21:41:59.202 -> 0:1:5 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200013F4 bat=24.89,0.000(0.02) chg=0.09,0(0.00) diff=-24.811 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=65.25
21:42:00.454 -> BUTTON 1s
21:42:00.669 -> stateButton 1
21:42:00.743 -> COMM CRC ERROR: ;N%N&*r+.
21:42:00.881 -> BUTTON 1s
21:42:01.061 -> stateButton 1
21:42:04.160 -> batTemp=998 cpuTemp=32
21:42:04.160 -> WARN: PID unmet cycle time Ta=0.13 TaMax=0.10
21:42:04.194 -> 0:1:10 ctlDur=0.02 op=Idle(initiatedByOperator 0) freem=244763 sp=200000A4 bat=24.89,-0.000(0.02) chg=0.07,0(0.00) diff=-24.807 tg=0.00,0.00 x=0.00 y=0.00 delta=-0.25 tow=0 lon=0.00000000 lat=0.00000000 h=0.0 n=0.00 e=0.00 d=0.00 sol=0 age=70.25
21:42:04.194 -> Info - LoopTime: 5 - 2 - 3.87 - 105ms
21:42:04.716 -> COMM CRC ERROR: ;N%M&*r+-
21:42:06.737 -> COMM CRC ERROR: ;N%N&*r+.
