void Robot::checkPerimeterFind(){
if (!perimeterUse) return;
if (stateCurr == STATE_PERI_FIND){
if (perimeterInside) {
// inside
if (motorLeftSpeedRpmSet != motorRightSpeedRpmSet){
// we just made an 'outside=>inside' rotation, now track
setNextState(STATE_PERI_TRACK, 0);
} else {
// we are outside, now roll to get inside
motorRightSpeedRpmSet = -motorSpeedMaxRpm / 1.5;
motorLeftSpeedRpmSet = motorSpeedMaxRpm / 1.5;
//PID controller: track perimeter
void Robot::motorControlPerimeter() {
//3 states
//wire is lost
//On the wire staright line pid fast action
//Back slowly to the wire pid soft action
//Control the perimeter motor only each 30ms
if (millis() < nextTimeMotorPerimeterControl) return;
nextTimeMotorPerimeterControl = millis() + 30; //possible 15ms with the DUE
//PerimeterMagMaxValue=2000; //need to change in the future
//tell to the pid where is the mower (Pid.x)
perimeterPID.x = 5 * (double(perimeterMag) / perimeterMagMaxValue);
//tell to the Pid where to go (Pid.w)
perimeterPID.w = -0.5;
else {
perimeterPID.w = 0.5;
//parameter the PID
perimeterPID.y_min = -MaxSpeedperiPwm ;
perimeterPID.y_max = MaxSpeedperiPwm ;
perimeterPID.max_output = MaxSpeedperiPwm ;
//and compute
perimeterPID.compute();
//First state wire is lost
//important to understand TrackingPerimeterTransitionTimeOut It's if during this maximum duration the robot does not make a transition in and out then it is supposed to have lost the wire, the PID is stopped to go into blocking mode of one of the two wheels.
// If the trackingPerimeterTransitionTimeOut is too large the robot goes too far out of the wire and goes round in a circle outside the wire without finding it
// If the second condition is true the robot has lost the wire since more trackingPerimeterTransitionTimeOut (2500ms) for example it is then necessary to stop one of the 2 wheels to make a half turn and find again the wire
if ((millis() > stateStartTime + 10000) && (millis() > perimeterLastTransitionTime + trackingPerimeterTransitionTimeOut)) {
//If this condition is true one of the 2 wheels makes backward the other continues with the result of the PID (not advised)
if (trackingBlockInnerWheelWhilePerimeterStruggling == 0) { //
rightSpeedperi = max(-MaxSpeedperiPwm, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 + perimeterPID.y));
leftSpeedperi = -MaxSpeedperiPwm / 2;
else {
rightSpeedperi = -MaxSpeedperiPwm / 2;
leftSpeedperi = max(-MaxSpeedperiPwm, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 2 - perimeterPID.y));
//If this condition is true one of the 2 wheels stop rotate the other continues with the result of the PID (advised)
if (trackingBlockInnerWheelWhilePerimeterStruggling == 1) {
leftSpeedperi = 0;
else {
rightSpeedperi = 0;
//send to motor
setMotorPWM( leftSpeedperi, rightSpeedperi, false);
// we record The time at which the last wire loss occurred
lastTimeForgetWire = millis();
// if we have lost the wire from too long time (the robot is running in a circle outside the wire we stop everything)
if (millis() > perimeterLastTransitionTime + trackingErrorTimeOut) {
Console.println(F("Error: tracking error"));
addErrorCounter(ERR_TRACKING);
//setNextState(STATE_ERROR,0);
setNextState(STATE_PERI_FIND, 0);
// out of the fonction until the next loop
return;
// here we have just found again the wire we need a slow return to let the pid temp react by decreasing its action (perimeterPID.y / PeriCoeffAccel)
if ((millis() - lastTimeForgetWire ) < trackingPerimeterTransitionTimeOut) {
//PeriCoeffAccel move gently from 3 to 1 and so perimeterPID.y/PeriCoeffAccel increase during 3 secondes
PeriCoeffAccel = (3000.00 - (millis() - lastTimeForgetWire))/1000.00 ;
if (PeriCoeffAccel < 1.00) PeriCoeffAccel = 1.00;
rightSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 1.5 + perimeterPID.y / PeriCoeffAccel));
leftSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm / 1.5 - perimeterPID.y / PeriCoeffAccel));
else
//we are in straight line the pid is total and not/2
rightSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm/1.5 + perimeterPID.y));
leftSpeedperi = max(0, min(MaxSpeedperiPwm, MaxSpeedperiPwm/1.5 - perimeterPID.y));
//if the mower move in perfect straight line the transition between in and out is longuer so you need to reset the perimeterLastTransitionTime
if (abs(perimeterMag ) < perimeterMagMaxValue/4) {
perimeterLastTransitionTime = millis(); //initialise perimeterLastTransitionTime in perfect sthraith line
// PID controller: track perimeter
void Robot::motorControlPerimeter (int speedPwm) {
//3 states
//wire is lost
// PP: modified for inverse perimeter direction
perimeterPID.w = invertPerimeterDirection ? 0.5 : -0.5;
} else {
perimeterPID.w = invertPerimeterDirection ? -0.5 : 0.5;
//parameter the PID
perimeterPID.y_min = -speedPwm;
perimeterPID.y_max = speedPwm;
perimeterPID.max_output = speedPwm;
//and compute
// transition in and out then it is supposed to have lost the wire, the PID is stopped to go into blocking mode of one of the two wheels.
// outside the wire without finding it
// it is then necessary to stop one of the 2 wheels to make a half turn and find again the wire
if (invertPerimeterDirection) {
// PP: reverse code
rightSpeedperi = -speedPwm / 2;
leftSpeedperi = max(-speedPwm, min(speedPwm, speedPwm / 2 + perimeterPID.y));
} else {
rightSpeedperi = max(-speedPwm, min(speedPwm, speedPwm / 2 - perimeterPID.y));
leftSpeedperi = -speedPwm / 2;
} else {
// PP: original code
rightSpeedperi = max(-speedPwm, min(speedPwm, speedPwm / 2 + perimeterPID.y));
} else {
leftSpeedperi = max(-speedPwm, min(speedPwm, speedPwm / 2 - perimeterPID.y));
// PP: reverse code
rightSpeedperi = 0;
} else {
leftSpeedperi = 0;
} else {
leftSpeedperi = 0;
} else {
rightSpeedperi = 0;
//send to motor
setMotorPWM (leftSpeedperi, rightSpeedperi, false);
return;
// PP: reverse code
leftSpeedperi = max(0, min(speedPwm, speedPwm / 1.5 + perimeterPID.y / PeriCoeffAccel));
rightSpeedperi = max(0, min(speedPwm, speedPwm / 1.5 - perimeterPID.y / PeriCoeffAccel));
} else {
rightSpeedperi = max(0, min(speedPwm, speedPwm / 1.5 + perimeterPID.y / PeriCoeffAccel));
leftSpeedperi = max(0, min(speedPwm, speedPwm / 1.5 - perimeterPID.y / PeriCoeffAccel));
} else {
// PP: reverse code
leftSpeedperi = max(0, min(speedPwm, speedPwm/1.5 + perimeterPID.y));
rightSpeedperi = max(0, min(speedPwm, speedPwm/1.5 - perimeterPID.y));
} else {
rightSpeedperi = max(0, min(speedPwm, speedPwm/1.5 + perimeterPID.y));
leftSpeedperi = max(0, min(speedPwm, speedPwm/1.5 - perimeterPID.y));
void Robot::checkPerimeterFind() {
if ((stateCurr == STATE_PERI_FIND) || (stateCurr == STATE_PERI_FIND_FOR_MOW)) {
// inside
setNextState (STATE_PERI_TRACK, 0);
} else {
// PP: reverse code
motorRightSpeedRpmSet = motorSpeedMaxRpm / 1.5;
motorLeftSpeedRpmSet = -motorSpeedMaxRpm / 1.5;
} else {
} else if (stateNew == STATE_STATION_ROLL){
motorLeftSpeedRpmSet = motorSpeedMaxRpm;
motorRightSpeedRpmSet = -motorSpeedMaxRpm;
stateEndTime = millis() + stationRollTime + motorZeroSettleTime;
} if (millis() >= stateEndTime) setNextState(STATE_STATION_ROLL, 0);
} if (millis() >= stateEndTime) setNextState(STATE_STATION_ROLL, 1);
