jonathanbyrn
I am trying to connect my bluetooth module to pfodApp and arduRemote and while it connects (and the LED on the board lights up) nothing is showing up on the screen.
I had a problem setting up the bluetooth through the serial monitor as the board doesnt seem to detect it. I have set the key pin to 3.3v using a jumper and I have 5v going to the module. I am also entering setup mode by holding the button on startup and the light is flashing slowly, which means it is in command mode. It just returns error detecting baudrate.
I can connect the same bluetooth module to an uno board and send AT codes to it with no problem. Any ideas why it cannot see the bluetooth module and how I could go about debugging it?
