senil
Hello,
After the first tests in the field, I have seen how it has worked really well. He has made the cuts and walked wonderfully.
The big problem and my misfortune is that it got caught on one of the edges of the terrain and after digging with the wheels, the disc must have gotten stuck in the ground and after a few seconds without being able to turn, something must have melted and now nothing turns anymore.
The mower moves correctly, but does not cut or show signs of wanting to turn.
I have tried to make it rotate using the button on the APP but that doesn't work either.
I guess some fuse or component (Drive or Adapter).
As my knowledge of electronics is quite low, I have only been able to verify that there is a 24V current in this area. But it is impossible for me to know where it might have gone wrong.
I also don't know if you can give current directly to the motor to see if it turns and rule out that it is something internal inside it.
What points of the Brushless Adapter could I try to look at or perform some test with a current test?
I think I'm at an impasse, since there are no controllers or adapters for brushless motors yet, and it seems to me that this will go a long way.
I emphasize that I have little knowledge of electronics and in the forums I see that there is not much that I can try to solve a similar problem.
I feel ashamed because I do nothing but give problems and few solutions to other users.
Thank you very much for your patience.
Best regards.
Best regards.
