Apparently the PCB is supposed to use energy from the wall to power the mower when docked:
The PCB also limits energy coming from the battery when its shutdown.
The problem is that the ACT drivers that come with the ardumower kit plug directly to the battery and draw a constant 0.2 amps.
This means that if the mower shuts down it will continue to drain untill the battery BMS triggers, also when docked it will keep charging and discharging constantly.
Why does the wiki say to connect directly to the battery?
Is there a way to run the motor driver board through the PCB instead of directly from the battery?
Any other ideas?
Thanks.
Mainboard V1.4 Ladestrategie
Hallo, soweit ich das verstehe, kann der Ardumower nur geladen werden, wenn er eingeschaltet ist und die SW läuft. Ansonsten wird das Relais zu Ladung ja nicht angesteuert. Aber damit verbraucht der Mower natürlich permanent Strom. Und ich kann den Mower bei Problemen (SW stürtzt ab...
forum.ardumower.de
Any other ideas?
Thanks.
