Hello everybody,
I actually started to make an remote crontrol track (like tank tracks) lawnmower( gas powered ) until i stumbled upon ArduMower.
I thought it would be fun to integrate ArduMower electronics to my soon to be tracked lawnmower.
I have a few questions if anybody can help me answer:
- how long can the perimeter line be? I have read that it can be max 1000m2; but the problem is becuse my lawn is something like 2000m2. Is it possible to get the perimeter line working on such bigger terrain?
- How does the LINE PATTERN mowing works? is it fully functional? And how does it behaves on steeper hillsides? I the steepest part is about 35 to 40 degrees. Would the ArduMower able to held a straight line? Keep in mind that it will use wide tracks so it probably wont have problems on steep terrain.
- Does Ardumower has adjustable cutting width? My lawnmower will have a 50cm cutting width.
- Can i change the ArduMower code to my specifications? Is it fully open-source?
My lawn is fully fenced so i have almost none safety problems about this project if anything goes bad.
Thank you very much!
Alen
Alen
