max@birley_com
Before making my 1.3 PCB I am messing around with the arduino mini. I have uploaded the code to a mega with extension shield version 1.04, selected mini in config. I am using 2 L298n motor controllers and the motor test is working well.All seems like it is going in the correct direction
One question. The wheels even on full power during the motor test are no turning at max rpm or even close to it. What parameter should be used to increase rpm and what would the max value be? as I do not want to burn anything out. i am using 12v motors for now
The main problem I have and want to help with I think is simple. When the button switch connected from pin 51 to ground is pressed it does not have any impact on the buzzer connected to pin 53 and ground . i.e. when I press the button I do not hear any beeps so I can not choose a operational setting.
Can you point me to the parameters that control this.
I do not have anything else connected to the arduino other than the motor drivers and the motors. so no perimeter, sensors nothing
regards
Max
regards
Max
